BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
proTUNING Freaks
      04-08-2024, 01:24 AM   #4115
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
Again - you have major corrections going on! Your fuel is terrible! Crap fuel - crap performance. You need (much) better fuel if you are experiencing corrections on a stage 1 RON 95!
Your stage 0 looks ok-ish but even there it is visible that your fuel is low octane!
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
      04-08-2024, 03:15 AM   #4116
ycilgin
ycilgin's Avatar
Turkey
Drives: BMW M240i xDrive
Thanks for your reply again. Can there be something else that may be causing this crapy performance? I know I don’t have the best fuel but I also know also people who are making power out of this fuel. Spark plugs are 10k kilometers old.
      04-08-2024, 03:23 AM   #4117
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
I don't think so. Your Stage 0 map is running ok, although still suggesting suboptimal fuel. This to me proves it is the fuel, not spark plugs or anything else.
Try different fuel or start adding Ethanol. Don't kill you engine with this one.
      04-08-2024, 06:38 AM   #4118
Shaun4d
Drives: B58 340i
Can anyone confirm what is reducing my load limit after 6,300 rpm on the second WOT pull (see link to log below)
https://www.bootmod3.net/log?id=6613...7984464cd92501
My first guess is component protection due to EGT or similar but would be great if someone could advise.
Apologies that the log doesn't just contain the WOT pull data (I have have been checking log data during steady state conditions too)
      04-11-2024, 05:27 AM   #4119
muumio
Drives: M140i xDrive
Originally Posted by UpperAustriaM40i View Post
Ah ok, sorry, didn't see it.
As I said, in my opinion too much timing corrections.
I would try the 95oct map and see, if there are less corrections.
I switched to 95 map and did some runs before switching back to OEM map before having time to replace ignition coils.
And today I changed all ignition coils (OEM Bosch) but I wasn't able to do good pulls but ones I did and compared to previous similar pulls there is huge difference in timing corrections. So far only cylinder 1 is doing few (but less than before). I'll add new logs when I have time to do so.
Anways, are old ignition coils (as attachment) looking normal? I guess those are pretty old if not original. Spark plugs were changed ~5000km ago and there was no visible dust, oil or anything else exceptional.
      04-11-2024, 05:59 AM   #4120
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
Unlike spark plugs - you cannot tell much about the condition of coils just by their look... it is all internal.
      04-15-2024, 03:21 AM   #4121
w00t
Drives: G30 540xi
Can someone take a look at this log file and tell me if there is something i should worry about?
https://datazap.me/u/w00t/stage-2?log=0&data=23
Car is 540 stage 2+(98 ron map ) on 100 ron fuel with the current mods:
HJS 300 cel high flow cat, everything else stock
K&N drop in filter
TU Pump
Masata chargepipe
NGK sparkplugs, stock gap
My concern is with the timing corrections on cyl2 and cyl4 and the off target on the exhaust vanos.
Thanks in advance.
      04-15-2024, 05:48 AM   #4122
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
Are you mixing up RON and AKI?
Where are you? 100 is most likely RON.
And the 93 you are referring to cannot be RON, it is AKI (equivalent to 98 RON).
You should be more worried about the timing delta for knock being pulled at the beginning. Not much, but indicating you could use a bit better (higher octane) fuel.
You can drive as is if you choose to, but keep an eye on the logs as temperatures increase…
      04-15-2024, 07:21 AM   #4123
w00t
Drives: G30 540xi
Europe.
Will try with a bit of octane booster to see if there is a difference.
      04-15-2024, 07:23 AM   #4124
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
That means you are using the AKI 93 map (= RON 98 map) with RON 100 fuel. Don’t confuse them
Use ethanol instead of octane boosters.
      04-15-2024, 07:34 AM   #4125
w00t
Drives: G30 540xi
Edited the original post. Thank you.
Are u suggesting using a little bit of ethanol to smoothen out the corrections and the timing delta for knock? If so should i be switching the map to a more aggresive one, or the current should be fine? I don't want to install flexfuel kit or calculating the E content every time i fill up, that's why im asking for the optimal solution.
      04-15-2024, 08:44 AM   #4126
blacksapphire440i
Novice
blacksapphire440i's Avatar
316
Drives: 2018 440i Gran Coupe
Not posting my log but posting a photo of my log because some people here had doubts about my hybrid turbo logs..
Look at this boost curve (not on a daw but on a full frame turbo)
      04-15-2024, 08:45 AM   #4127
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
Just add about 5-10% E! No need to change anything. The E increases the fuel octane. Start with about 5% and see how the logs are. Might be enough.
      04-16-2024, 06:39 AM   #4128
muumio
Stupid questions continues..
I feel myself total idiot because I don't understand what torque limit 131072 actually means. Cylinder fill limit is confusing me. I have tried to find answers with AI/Google/Youtube but I'm still confused.
Can someone try to explain a bit easier way about it, give me a hint am I doing something horribly wrong or what I should check next? Transmission is flashed with default xHP stage 2 map. Engine is B58 gen 1.
Recently changed parts
- vrsf high flow downpipe
- bosch oem ignition coils
- k&n high flow intake filter (~5000km ago)
- engine oil + filter (~5000km ago)
- transmission oil (~5000km ago)
- ngk spark plugs (~5000km ago)
With MHD stage 1 map, https://datazap.me/u/muumio/mhd-stag...-22-37&solo=22
First I accidentally flashed MHD stage 2 map while setting aftermarket DP option for quick test run after installing high flow DP, https://datazap.me/u/muumio/mhd-stag...-26-47&solo=26
EDIT: I was able to go for another run with correct map.
      04-16-2024, 08:13 PM   #4129
RCS5696
Drives: BMW m240i
B58 Stage 2 93 log review
18’ m240i with BM3 Stage 2 93 tune. How’s the log look? From what I understand timing corrections less than 3 and no knock are good?
https://bootmod3.net/log?id=661f16d913417d1edeb7ebe3
      04-16-2024, 10:24 PM   #4130
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
498
Drives: BMW 340i xDrive
Looks okay but I would check how it runs in hotter weather. You're getting minor corrections on all cylinders now but as it heats up outside that may increase.
Dustin Braun @ Braun Performance Tuning
      04-16-2024, 10:26 PM   #4131
WrxToBeamerGuy
498
Stage 1 and stage 2 actually look perfectly fine. Those fill limits are part of the tune and nothing you're doing wrong.
      04-17-2024, 01:39 PM   #4132
RCS5696
Drives: BMW m240i
Thanks for the advice. It was about 85 degrees ambient when running the logs. I live in the south so it gets pretty hot. May end up switch to the 91 map once it gets hotter. Shell 93 here seems to be pretty good.
      04-17-2024, 10:53 PM   #4133
muumio
Ok, thanks :-)
      04-18-2024, 12:06 PM   #4134
Michalt
Michalt's Avatar
Drives: 340i
Can someone looks to my log and says is everythink is good?
Gen1, Masata catted DP, RON98, St2 MHD
https://datazap.me/u/black340i/log-1...25-26-27-28-29
Thanks
      04-18-2024, 12:15 PM   #4135
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
Looks ok.
      04-19-2024, 12:57 PM   #4136
Krisztian93
Drives: Bmw 540i g30
Hi Guys I have a b58 , and my logs are okay im on stg2 Mgflasher 98 ron- but my Boost The map asks for 16-17psi and mine starts dropping after 5700 rpm 15.5 and then comes back slowly can you guys check my log
This was 3-4th gear i believe
https://logs.mgflasher.com/log/14cbb...0=&wide=1&vt=2
Second one in 3rd gear
https://logs.mgflasher.com/log/14cbb...0=&wide=1&vt=1
Third one 3-4th i believe
https://logs.mgflasher.com/log/14cbb...19&wide=1&vt=0
