02-07-2024, 12:42 AM | #640 |
Rep 15
02-17-2024, 08:41 AM | #641 |
Rep 4
Drives: 2018 430XI grand coupe
I am looking for links to download the programming files for my BmW 430, and hear you are the coding guru. I bought a wrecked 2018 430XI and rebuilding currently. Need to code new headlight module to the car as driver side is not working. I am going to try to recode the light module and reset a lot of codes before replacing a lot of expensive hardware components. Any help as to what I need to download for this. Beginner on programming/coding on vehicles but ready to learn. See I need e-sys, pszdata, launcher. Anything else you recommend.
02-23-2024, 06:09 AM | #642 |
Rep 5
What am I missing
Hi guys,
So long story short. I bought my 2018 BMW G01 with an I drive 7 cluster in. Nothing really worked correctly, so I asked the garage to install the correct cluster which they did. I only found out later that the installed cluster was the low spec cluster and not the correct Professional 6WB cluster. I went around and found the correct cluster and now I find out I need to get it virginized. Took it to some dude that removed the eprom but told me the chip is locked and he could not do it. Keep in mind, I am probably the first person in South Africa to even try this. So here I am, asking for help. How can I see if the cluster I bought will work? I read you need to upgrade the software before it can work, so I would need someone to do it for me. I am not tech savvy. Who can assist? Thx |
02-23-2024, 10:18 AM | #643 | |
General
10526
Rep 41,145
03-19-2024, 07:13 PM | #644 |
Rep 4
Drives: bmw f20 118i
03-22-2024, 04:15 AM | #645 |
Rep 536
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
04-14-2024, 10:42 AM | #646 |
Rep 6
Hi guys,
how is going? Wanted to ask if someone of you have time to help me with the coding 6WB and mine BMW F36. I have an software E-Sys, cable and evertyhing I just stucked with the coding. If you have time please let me know I will pay you for your instructions. Thank you, Best Regards |
04-14-2024, 10:43 AM | #647 | |
General
10526
Rep 41,145
04-15-2024, 08:14 AM | #649 |
Rep 6
Hi guys,
did someone had the problem with deleting BKOMBI file? Unfortunately I deleted it and now I can recover it? Does anyone know solution how I can recover or create new BKOMBI / DKOMBI file? Thank you very much. |
04-15-2024, 10:33 AM | #650 |
General
10526
Rep 41,145
You need to make sure DKOMBI has Fiber Option Connection.
04-29-2024, 10:03 PM | #652 |
Rep 4
I have got 6wb need to code it to my bmw f20
04-30-2024, 04:09 PM | #653 |
Rep 4
No still try but no luck so I’m not that good at coding here is my number can someone massage and help me code with teamview
0401704001 |
05-01-2024, 01:29 AM | #654 |
Rep 536
F20 doesn't have 6WB just 6WA
