BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > xDrive 1% Difference in Rolling Diameter - Myth?
Extreme Powerhouse
      01-13-2022, 06:25 AM   #67
RobertMarian
Drives: Bmw 3 series f34 30d xdrive
Hi there , im new here , i have a f34 330d xdrive and i would like to upgrade the wheels from 19x8 front and 19x8,5 back with 20x8,5 front and 20x9 back , any advice on what tires i sould get to not mess up the xdrive system?
      01-13-2022, 10:49 AM   #68
alohasurftoad
Drives: 440i gran coupe w/mppsk
235/35/20(26.5"), 275/30/20(26.5")
235/35/20, 265/35/20(26.3"), 0.8% difference
225/35/20(26.3"), 255/30/20(26.1"), 0.4%
      01-13-2022, 11:07 AM   #69
Ennoch
2263
Drives: F31 335D XDrive
Originally Posted by hurst01 View Post
I don’t find that to be true. I have had two different BMW X Drives, both 535 cars. I have run both staggered and square setup. I have never seen the rear tires wear faster than the fronts. You can’t rotate a staggered set because the rears won’t fit the front and would really look strange if you did.
If your rear tires wear faster than the front you have a problem. The rear tires will not spin independently from the front enough to wear tires unless the transfer case is out.
Ed
The original owner of mine definitely wore the fronts out before the rears but my experience of the PS4's and the winters is that if you drive country roads properly, as most of my driving is, then the rears take a significant portion of the torque and thus wear marginally faster than the fronts. If you are using weight transfer and getting on the power to slingshot out then it's the rears which are getting the biggest hammering from both the weight transfer (i.e the rear squatting down) and the rear tyres getting most of the torque (i.e if you've got a skew angle on the go). However, a lot of owners don't really drive their cars properly which means going into corners too quickly, understeering, turning the wheel too much and then only getting on the power once the car's straightened up and it's this which tends to kill front tyres faster than the rears.
      11-27-2022, 08:25 PM   #70
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
Originally Posted by kzflags View Post
its almost a given now that the rule of thumb to follow for xdrive vehicles is to keep the rolling diameters within 1% front and rear. However, from an online manual (which the link is expired lol) it states:
"The tire circumference can fluctuate up to 1% or more as a result of mixed tires or wear. The tire tolerance logic decides depending on the driver's command and driving situation whether the slip is to occur in the transfer case clutch or at the contact area between tire and road.
If the slip is permitted in the transfer case clutch, the locking pressure set by the pre-con- trol is reduced in order to keep the work loss low. In the driving dynamic control situation, the clutch is locked slightly more than normal, the four wheel drive is always guaranteed when required.
For maximum xDrive performance, tires (and wheels) of the same diameter should be installed on the vehicle."
Sorry to revive this post from the dead, but I've been researching this too and figured to add context.
This quote is from the E83/53 xDrive training document. That chassis uses an older ATC 400/500 transfer case. The F3x transfer case is a newer ATC 35L unit. Aside from both being chain-driven TCs, I'm not sure where the similarities end.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World
      07-31-2023, 11:26 AM   #71
PeteyF36
PeteyF36's Avatar
Drives: 20 440i xDrive GC,sc300 TURBO
Again sorry to revive a old thread
im looking to replace my 225/45/18 square setup with a 245/40/18 and car is xdrive
so trying to match up a spare tire kit since ill be taking off the run flats and closest ive found is with 1.2%. only time i would be running that spare is if a tire goes out. so for a short time i would be on it would it ruin the system?
2020 440xi Gran Coupe ///M Sport B39 Mineral Grey Metallic
Kyostar Intake | CTS Charge Pipes | BM3 Stg 2 | XHP Stg 3 | RVG DP | H&R Springs |
      07-31-2023, 12:38 PM   #72
visionaut
visionaut's Avatar
Drives: 2016 435iX GC & 1976 2002
You should be fine with that difference for short-term spare use.
      07-31-2023, 12:39 PM   #73
PeteyF36
PeteyF36's Avatar
visionaut
thanks so much
      11-28-2023, 09:42 AM   #74
stevegwill600
stevegwill600's Avatar
Drives: bmw 320i msport x drive
tyres
how would 245/35/20 and 275/30/20 fear on the x drive?
      11-28-2023, 03:17 PM   #75
visionaut
visionaut's Avatar
As noted by Aloha in post #68 above — the correct staggered 20” combo is
235/35/20 Front (26.5"), 275/30/20 Rear (26.5") for X-drive.
Note 26.5” is 1/2” larger diameter than OE tires.
      11-29-2023, 12:55 AM   #76
stevegwill600
Would you be able to run 245/35/20 on the fronts with 275/30/20 on the rear?
      03-08-2024, 12:19 PM   #77
Musashi
136
Drives: BMW 335i XDrive Laguna Seca
NO- dont play- go at https://tiresize.com/comparison/ and lets compare. My 2104 came with stock 225/35/20. going to your 245/35/20 is a 2.3% increase in circumference AND a heavier, much heavier tire!
For years I ran 225/35/20 and 255/30/20. P Zeor. rears worse nearly x3 faster than rears. Brutal, they were cheaper then they shot to 700$ a rear.
2017 grew up and went 19, with Japanese rays. Tried:
235/40/19
275/35/19 PS4S.
35,000kms brilliant! Ceramic rotors helped make it even more fun by dropping 30 lbs unsprung mass.
2021 MICHELIN PS4S Set #2.
225/40/19
265/35/19
Bubble defect, warranty swap to same. 235 wore the Dinan spring on one side, presumably backing up in my driveway.
19,000 kms on set #3. Meanwhile, Dec 2023, nearly losing the car with new X Ice snow- brand new, hardened after 3,000 kms on our first snow- Michelin. tested them on compact slush-the blocks hard, do nto open roll and slush over, no longer bite.
What happened? Michelin is now garbage and ditched by connoisseurs I know- cracks, bubbles, hardened compound. What happened is Michelin introduced a new polymer for longevity- a plastic- on all its models without changing names. At 6/32, the 2022 PS4S skids at 15C, hot to night chill thud thud thud for 15-20 kms, plastic deformation. Dec 2023, after the X Ice snow incident, Michelin recalled and bought me a new Hakkappellitta R5 winter set, mor eexpensive, direct JP Morgan deposit, brilliant on the 3,600 lbs car.
Have the PS4S now, 6/32, atrociosu noise and hardened plastic compound! Last season three Michelin Power Cup cycling tires failed on me, got refunded, no accident, my mom's AS 3+ hardned up after 5,000 kms, DONE WITH MICHELIN. I do not care about 60,000 km treadwear if they lose grip or thud like Kumho Koreans!
T Case- replaced 2021- 7000$. The culprit was me having fun, two dozen launch controls, the part shot up from 800$ to 5000$.
Now, with Bilstein B6, new HRE sway bars (Thanks Farkle), the car is better than it ever was new.
As my PS4S are due in 2 months, going to Continental Extreme Sport 02.
Reminder, my base stock TC program is 225/35/20 and 255/30/20. So I will go for
225/40/19 Conti or
235/40/19 Conti S02
Rear:
265/40/19 Conti S02 (-0.4%) or
275/35/19 Conti S02 (+0.8%)
All are within the 2014 Stock 2%. Hope for even wear.
      03-08-2024, 12:36 PM   #78
marcthedark
Drives: M240i xdrive Convertible
On my M240 the stock is 225/40-18 and 245/35-18 > a 1.35% difference
BMW must think that is OK for the long term so you are fine
