My CBU cleaning experience
01-19-2017, 11:22 AM | #89 |
![]() 798
Rep 3,574
Animal, was there any hassle involved in changing the valve cover? I recall that the design has changed (in what regard I do not know). I know the hassle of disconnecting the little injector feeds off of the common rail. My question was more in regard to what were differences in old and new cover please.
335dsleeper had told us of having to purge the fuel rail after he had disconnected the HPFP (he was hunting a problem that ultimately was a not fully seated electrical connector on the lifting pump). He may have ultimately changed the HPFP as part of the trouble shooting. My point of mention is it would be good to purge air out of the injector feed tubes. For anyone out there, does running the lift pump purge this area too? I'm not sure if flow can get past the HPFP. It would seem the injectors are dead headed even if you can purge the common rail itself. Seems I recall sleeper doing something to get a little flow out of the injector feed tubes with tube disconnected from injector's inlet. |
01-19-2017, 05:18 PM | #90 |
![]() 9
Rep 28
It seems purging air would have been good. I didn't know how to do that and didn't see any reference to such before.
The cover was basically the same. It's the multiple fasteners that are extremely tight to get to that we're the problem. And the fear of getting walnut chips in tre oil/engine when blasting with valve cover off. I taped everything off with plastic wrap changing frequently. Then I changed the oil shortly after car started and warmed up. |
01-29-2017, 03:13 PM | #91 |
![]() ![]() 809
Rep 1,192
Checking CBU after 25k miles. I'm running without meth and without an oil catch can. I guess this proves that you only need to block the EGR to prevent CBU.
01-29-2017, 04:42 PM | #92 |
![]() ![]() 331
Rep 1,157
I'm guessing this is a stock car, right? Looks shockingly clean! I lost the intake end of my EGR block somewhere in the engine bay, and now I'm just wondering if I should snag a race pipe from UK EBay or just get another metal circle from IA.
01-30-2017, 12:52 PM | #93 |
![]() 798
Rep 3,574
It all depends on if you want the EGR cooler to be there still. Don't forget we have a US supplied faux EGR housing from AARodriguez. If you delete cooler, there is the additional work for the water that goes through the cooler to either a) be bypassed or b) corked up with a plug.
01-30-2017, 12:59 PM | #94 | |
![]() ![]() 331
Rep 1,157
02-17-2017, 08:12 PM | #95 |
![]() 4
Rep 7
Question, would there be any significant disadvantage to cleaning the intake manifold by itself, i.e. not cleaning the engine side of the intake? I've got the intake manifold off for other reasons, but I was wondering why not give it a good cleaning while it's off? Would it create any issues, or exacerbate current cbu on the engine side, by only cleaning the manifold? (And I realize it would be better to do both at the same time, but I don't have access to the tools, unless someone in the LA area would be willing to lend out all the necessary parts to do it?)
. Last edited by GgOTi; 02-17-2017 at 08:45 PM.. |
03-06-2017, 01:27 PM | #96 | |
![]() 0
Rep 4
03-12-2017, 09:37 PM | #98 |
![]() ![]() 32
Rep 221
@[Mik325tds]
with the block off plate, did you ever go into limp mode? i blocked off the egr on the hot side with a small 35mm plate and got the p401 code... then later got the p402 code which i believe put me into limp mode... not fun... |
03-13-2017, 07:58 AM | #99 |
![]() ![]() 331
Rep 1,157
I also installed block off plates with no limp mode. It threw a few EGR codes, but none of them had me limping.
03-13-2017, 06:43 PM | #100 |
![]() ![]() 809
Rep 1,192
I never had a limp home mode with the EGR block and no tune and I did drive it quite a bit with that. Quite interesting that yours goes into limp. Have you tried updating your DDE SW?
05-31-2017, 12:17 PM | #101 |
BRR tuned
224
Rep 646
just wondering could I spin the motor over by hand? or is the starter a must....
Im doing my cleaning now... I don't have a blaster for the heads I was planning on running a flexible brush on a drill down the head to clean out as much as I can and get some meth working for me..... knowing how easy the manifold comes off I have no issues yanking it off again |
05-31-2017, 05:22 PM | #102 | |
Rep 1,622
You can turn over by hand but you'll need to verify the valves are closed. I chose to use a bore scope instead of removing the valve cover.
Gasoline works exceedingly well on carbon. You could put it in the runner, clean with a wire brush and then soak it up with a rag and blow it dry with compressed air. It might do the trick if you do not have the blaster. Quote:
06-12-2017, 10:02 AM | #103 | |
![]() 16
Rep 84
I did my CBU cleaning the hard way (brushes, chemicals, bore scope) ... ended up running some of the crap into the DPF cause i couldn't get the goo out of the runners... BIG giant hole in the DPF now :-). lesson being that it is easier to remove dry walnut shells, than wet GOO :-p |
Mik325tds809.00 |
07-02-2017, 12:59 AM | #104 | |
Rep 15
thanks for the excellent guide. the above section in your write up answers my question about using the starter to turn the engine. my other question is about the compressor setup. I have a good compressor that I want to use, but this piece of details seems to be skipped in almost every thread I have read on the cbu cleaning topic. I have bought this basic kit from amazon (http://a.co/flC7zjH) and the nozzle is removable, however it turned out to be too big for the little fitting the bmw wands seem to have. can you please explain how you attached the bmw wands to the blasting kit and what kit you used etc etc??? it would be awesome if you have pictures as well. thank you so much for your elaboration. |
07-05-2017, 05:51 PM | #105 | |
![]() ![]() 809
Rep 1,192
In order to attach the wands to the Harbor Freight blaster I pulled off the nuts from the BMW wand and used the nut from the noozle that came with the blaster. It wasn't a 100% tight fit but enough to not let any media through. |
07-05-2017, 06:28 PM | #106 | |
Rep 15
08-15-2017, 01:31 PM | #108 | |
![]() 15
Rep 64
08-15-2017, 04:27 PM | #109 |
![]() ![]() 809
Rep 1,192
08-20-2017, 05:02 PM | #110 |
![]() 56
Rep 238
Thanks Mik for the tools. Just want to add to the overall process. Took about 1.5hrs per cylinder to complete. Did it over 3 days @ 2 per day. Cylinder 6 was a PITA on the upper valve to get clean due to the firewall and cowl. Had to remove the wipers and trim out of the way to get that really hard to reach upside down curve but she came clean.
I did the EGR delete at the same time so any additional EGR Based soot has been eliminated. Oil catch can is waiting on a couple hoses but will be installed this week. No more funky shit in my intakes! The internal intake shots were from the worst before and after. The upper port shot external was probably the worst one. I will say that that process took a little time and I definately don't want to do it again, but it really wasn't that awfully bad. If your compressor is borderline or has seen some years this process might very well put it over the edge. BTW this is the camera that I used on my S8+. It provided an invaluable function in this overall process (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1). |
