02-28-2019, 06:23 AM | #1 |
107
Rep 100
FSC Code Generator for Nav update No waiting for a PM or "donating"
Here is a very easy FSC code generator that I found in the e90 forums:
https://www.e90post.com/forums/showthread.php?t=1453464 ..and here in the F30 forum https://f30.bimmerpost.com/forums/sh....php?t=1456836 Enjoy! If anyone needs some help, JLMK. 2019 NEXT Link: https://f15.bimmerpost.com/forums/at...0&d=1535168776 2019 Premium links: https://mega.nz/#!i24ESaTY!ZVETn8yf0...v5KvZde0PZYaXw 2018 Premium link (Torrent version): https://www.e90post.com/forums/attac...2&d=1551059175 Last edited by BackBlue; 03-15-2019 at 05:15 PM.. |
02-28-2019, 09:35 PM | #2 |
107
Rep 100
To pull the "open file" needed for the FSC Generator download ZIP LINK:
https://www.e90post.com/forums/attac...5&d=1518522964 1. Unpack the ZIP file (1b.zip) to the root of an empty USB stick (aka. jump, flash or pen drive and/or "stick". (be sure to use an empty drive and format the drive as FAT32) 2. Power on your car (ignition on is fine, you don't need to start your car) and wait until the navigation system has started completely 3. Put the USB stick in the USB port in the glove box or console, depending on vehicle. 4. Wait for around 30 seconds 5. Remove the USB stick from the port in the glove box and put it in your (windows) computer 6. Check if the file 1b.hex is present on the USB sticK, THIS IS the "OPEN FILE", save this to your computer and point the code generator to it. Last edited by BackBlue; 03-15-2019 at 03:45 PM.. |
BimmerLover21.50 |
03-15-2019, 04:19 PM | #4 |
588
Rep 2,302
Thank you, but have a look at this (here in the forum)...
https://f30.bimmerpost.com/forums/sh....php?t=1456836 |
03-15-2019, 05:20 PM | #5 | |
107
Rep 100
zrile100.00 |
10-20-2019, 01:38 PM | #6 |
Rep 2
Need help cant find FSC code
Hi, I am looking for fsc code (year 20150312)
fsc gen not finding the correct code. I have tried everything. Please help. Map type: Next Region: North America Map: Road Map North America Next 2020 -1 Vin: NT17639 production date: 03/2015 |
11-05-2019, 05:12 PM | #8 | |
17
Rep 47
Any tips? |
04-26-2020, 11:21 AM | #11 |
Rep 1
Hello guys, sorry if this incorrect place to post but, when i try to update my map, i always get the message "please insert USB device with correct activation code" i thought the FSC was entered before the update begins but it gives me no option to insert any code?
Any help is appreciated. yellow |
10-08-2020, 04:25 AM | #12 |
Rep 7
Can anyone help, I have tried everything to get the 1b.hex file off my car but nothing works.
I have also tried to manually input my long vin number into the FSC Generator but all the codes which get generated do not work. My vehicle is a 2013 F25 with the following navigation system: Europe BMW Group 101114014 Road Map Eurpoe MOVE 2013 I have got the Europe MOVE 2019 Map update file ready to go into my car but need the FSC code. The last 7 digits of my VIN: 0C69515 Please, please, please can someone help as im pulling my hair out with it! Thanks in advance |
10-08-2020, 04:45 AM | #13 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Do you have a ENET cable ?
04-15-2021, 05:10 PM | #18 | |
Rep 3
04-27-2021, 06:59 AM | #19 |
Rep 7
I have been told that the newest update of Road Map Eurpoe MOVE 2020 has now been seperated into East and West is this correct?
Does anyone have a link where I can download it from, my source has now started charging for it? Thanks everyone |
05-03-2021, 06:15 AM | #20 | |
Rep 5
Or only fsc.bat in the pendrive root before plugging to the USB car port? I tried several procedures in a 320 2007 and it's not working. Can you help please? My regards Jorge |
06-27-2021, 10:35 PM | #21 | |
Rep 3
i downloaded the latest maps and when inserted the usb, the unit is recognizing it and asking for start update, but next message is the same as before: "please insert USB device with correct activation code" |
