07-20-2023, 06:21 PM | #67 |
General
10526
Rep 41,145
As soon as you name and save FA, Edit becomes available.
07-21-2023, 12:27 AM | #68 |
31
Rep 46
Edit: See my post below (#74) for my final solution.
You are correct. Of course. Sorry about that. I feel like I'm really close now, but the FA is not getting written to the car. Sorry that I'm so slow. Thanks for your patience and generosity. Here are the steps that I just tried:
07-21-2023, 09:39 AM | #69 | |
General
10526
Rep 41,145
E-Sys - VO Coding Guide.pdf: https://mega.nz/#!EgIFAZKb!H12P6g_2p...j4BT5UCMxck1bw
07-21-2023, 10:42 AM | #71 |
General
10526
Rep 41,145
It is up to you. You can write modified FA to VCM or not. For Coding, all that is needed is that modified FA be loaded in Coding Module and affected ECU's are VO Coded.
07-21-2023, 10:54 AM | #72 | |
31
Rep 46
I'm a bit confused by your note on page 14. Does skipping or not skipping pages 14-15 "avoid the risk of causing dealership programming issues with incompatible FA addition"? |
07-21-2023, 10:56 AM | #73 |
General
10526
Rep 41,145
If modified FA is valid for your build, you can write FA to VCM, and dealer Programming will treat it as a factory option. If FA is not valid for your build, do not write it to VCM.
07-22-2023, 10:50 PM | #74 | |
31
Rep 46
For anyone trying this in the future, here are the steps that finally worked for me:
07-22-2023, 10:52 PM | #75 |
General
10526
Rep 41,145
08-03-2023, 04:14 PM | #76 | |
Jon Y
Rep 28
08-23-2023, 09:15 PM | #77 | |
Rep 12
08-23-2023, 09:17 PM | #78 |
Rep 817
Drives: bmw M3 F80
08-23-2023, 09:25 PM | #80 |
Rep 817
Drives: bmw M3 F80
08-24-2023, 12:52 PM | #81 | |
31
Rep 46
Aside from that problem, did the rest of the instructions work for you? Let me know if there are any errors, and I will edit my post above to include your corrections. |
08-24-2023, 02:55 PM | #82 | |
Rep 12
08-25-2023, 01:06 PM | #83 | |
31
Rep 46
If you don't mind me asking, how did you bleed the brakes after installing the new calipers? Ironically, I'm still fighting a VERY soft brake pedal. I did the full ISTA bleed procedure, including the cycling/vibration of the DSC system. However, I did the ISTA procedure with the engine NOT running. I'm going to try the ISTA bleed procedure again with the engine actually running to see if that fixes it. I've already gone through 3 L of brake fluid and ordered 2 L more, so the cost is starting to add up ($25/L). I'm using the Pentosin DOT4 LV (low viscosity) brake fluid. |
08-27-2023, 01:04 PM | #84 |
Rep 12
I just did the standard bleed/flush procedure using a pressure/power bleeder. I did however do it 3 times since initially I thought that was the cause of soft pedal. Makes me want to try to Ista process to see if I get better brake performance. I used the same brake fluid you did.
05-04-2024, 03:49 PM | #85 |
Rep 3
Hello guys, i have a question.
I want to remove m sport brakes 340mm front 345mm rear from my f30 and put regular 312mm front and 300mm rear discs with calipers and everything. So i want to know is the any coding needed after that or? Thanks in advance! |
