12-09-2023, 04:32 PM | #1 |
Rep 1,599
Interior trim restoration/repair tips
Common sense preventive measures (that I should not have ignored):
1. Place protective towel on center console trim and around area where you remove the Head Unit. I damaged the paint on my center console (gear shift). 2. Place protective layer on seats and door liners when using a soldering iron. Even if for 10 seconds. Or you burn a hole in both, like I did. Solutions: Unless you get a color match at a pro-store and pay the premium, could not find any silver paint that matched the trim. With off the shelf spray cans, the closest I got was about 80%. But the new surface paint got easily damaged with everyday use. Took me a long time to find a wrap that is about 95-100% (depending on the ambient light) the same as my interior Silber Satin (Silver satin) 9218919 trim. 3M 1080 S120 SATIN WHITE ALUMINUM Vinyl Vehicle Car Wrap About $15 on Ebay for 5f x 1ft and $20 on Amazon For upholstery tears/burns/holes this was a 98%-100% solution. I truly could not find the repair spot later, had to look really close to locate a slightly different shading: 3M Leather and Vinyl Repair Kit $11.99 at Walmart
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
12-09-2023, 05:22 PM | #2 |
Rep 16,181
I got a crease in my seat that vinyl repair couldn't handle. I tried a piece of this, not expecting much. It's been doing the job for three years, with not a hint of lifting. https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
fe7565556.50 |
12-09-2023, 05:29 PM | #3 | |
Rep 1,599
