BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Noob question: Using 47ET at the back, could I go down?
proTUNING Freaks
      05-08-2024, 06:44 AM   #1
morcsekovszky
morcsekovszky's Avatar
Drives: BMW F32
Hello!
I bought the car, an F32 with the following setup:
For the tires.
225/40 R19 -front
255/35 R19 -back
For the rims.
8Jx19 ET36 -front
8.5Jx19 ET47 -front
Im planning to buy new rims for the summer, but with ET47 its really hard to find one.
Could I go down to like ET40-45 for the back? Will the tires fit, will the geometry be bad? -What would you guys do, maybe new set of tires?
Sorry for beginner question, tried to search the web, but there are some questionable and different answers everywhere.
Good day
      05-08-2024, 06:46 AM   #2
mbanks21
mbanks21's Avatar
1276
Drives: 2015 335i MSport
You could go down to the 20s it wouldn't matter unless you're lowered
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
      05-08-2024, 06:49 AM   #3
morcsekovszky
Drives: BMW F32
Im lowered a bit, but not that flush that it would be a problem.
So as for the tires, it doesent change a bit just how it sits on the car, is that correct?
Also, after I do like ET43-44-45 etc.. I should align the car and all fine, right?
      05-08-2024, 06:52 AM   #4
mbanks21
mbanks21's Avatar
1276
The "et" is the offset which is basically just the distance from the hub to the inner edge of the wheel. Et37 would be like putting a 10mm spacer on the stock wheel which people do all the time. No alignment is needed
      05-08-2024, 11:22 AM   #5
morcsekovszky
Drives: BMW F32
Alright I understand now
I actually have spacer, but its still not sticking out crazy so these just gives some plus mm. Epic, thanks man, really appreciate it.
