04-13-2023, 12:12 AM | #1 |
95
Rep 205
Oil getting "over-cooled" before reaching operating temp.
I’ve searched and can’t find anything related to this. I have a hot climate package for B58 340 which, when the car is driven hard, kicks in additional cooling and brings my oil temps below operating temp. This is fine and great. My issue however is after sitting in the paddock for an hour and temps go down, the car needs a full 10-15 min of easy driving in comfort to reach operating temps before I bang on it. This is problematic when it’s time to go on track I either have to drive in comfort below 3k ish rpm for several laps or go drive around before a session for 15 minutes before I can go WOT.
My 340 isn’t my track car so this really hasn’t been a problem until I decided to take it out for the first time. The car is tuned with bm3 which has a “max cooling” setting and this is not on. I presume this is just part of my hot climate package or possibly it’s just how the cooling works on this car I’m not sure but I’m desperate for a solution. |
04-13-2023, 08:35 AM | #2 | |
2088
Rep 2,649
Run slightly thicker oil (0w40, 5W30) and after the first time the car hits operating temperature, and you let it cool down, it's okay to WOT even if temps are down. The B58 keeps it's heat for 24-48 hours internally. Just do a tire warm up lap, and you'll be fine afterward doing WOT, oil takes a ton of time to cool down in summer temperature.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
04-13-2023, 12:34 PM | #3 | |
95
Rep 205
I understand that it takes less time to get to an operating temp when it’s not a complete cold start, but granted the oil temp thermostat is accurate, would colder oil not be ideal regardless? |
04-13-2023, 02:07 PM | #4 | |
2088
Rep 2,649
Hein Jockins94.50 |
04-13-2023, 03:32 PM | #5 | |
95
Rep 205
04-13-2023, 09:59 PM | #6 | |
2088
Rep 2,649
It only goes up to temp for fuel efficiency, operating temps is somewhere between 1/4 and halfway mark. |
F32Fleet3629.00 |
04-13-2023, 10:16 PM | #7 | |
95
Rep 205
My understanding of normal operating temp would be at this mark in the photo (somewhere around 220*F). The cooling I'm referring to will prevent the temps from getting above ~185*F. Which is right below the first 1/4 tick. Interestingly enough, the additional cooling will kick in even with moderate throttle. I'm not sure the "algorithm" the DME uses, but it has to be kept below 3k rpm with a steady application of throttle to avoid this cooling. I'm just surprised I couldn't find any info on this--unless people aren't too concerned about operating temps or don't track 340's. I come from the E9x M3 platform where oil temp/bearing paranoia is rampant so perhaps I'm the problem. |
04-13-2023, 10:36 PM | #8 | |
118
Rep 328
04-14-2023, 05:10 AM | #9 | |
2088
Rep 2,649
Now if the DME detects alot of WOT, it's going to kick in the additional cooling as you're now in "sporty" driving, my N55 did the same thing on the track, at some point, it was sitting at halfway, then the cooling kicked it and it would reduce to 1/4 or a bit below it. Hot temps is fine as long as the needle isn't going beyond half and staying there, the car is designed to run that hot for fuel efficiency, it also knows when you're pushing the car so it'll cool down itself. I also wouldn't be worried about bearings on the B58, they're coated for reduction of friction.
Hein Jockins94.50 |
04-14-2023, 07:45 AM | #10 |
204
Rep 383
Why not start your engine earlier to bring it up to temp if you're worried about it? Once your on the track the additional cooling shouldn't be an issue, just run a normal warmup lap for tires and go.
04-14-2023, 08:19 AM | #11 | |
95
Rep 205
05-23-2023, 07:20 PM | #12 |
Rep 1,130
After my first session in the morning oil temp remains in the zone even with an 1.5 hours between sessions. I am not sure what max cooling is doing, but I would just turn it off if it causes problems.
