02-24-2018, 09:12 PM | #1608 |
Rep 3
FSC code Please
Hi guys, I tried to use FSC code generator and i realized my operating system is windows 8 64bit and I was not able to generate FSC code. Can someone please PM me FSC code for my car. 2013 BMW 640i Gran coupe. Last 7 digits of VIN DZ03957. Current version: 112121.2.18. Road map North America Premium 2013-1A. TIA.
FlorinQCK-2.50 |
02-24-2018, 09:32 PM | #1609 | |
General
10526
Rep 41,145
FlorinQCK-2.50 |
02-24-2018, 09:41 PM | #1611 |
General
10526
Rep 41,145
That is a common problem. I have no way of knowing what the specific issue is.
FlorinQCK-2.50 |
02-26-2018, 06:31 AM | #1613 | |
Ü
77
Rep 473
FlorinQCK-2.50 |
02-26-2018, 02:58 PM | #1615 | |
Rep 10
FlorinQCK-2.50 |
03-01-2018, 04:41 PM | #1619 |
Rep 10
Hi all,
I know I may sound dumb. When tried to copy these folders to C drive I don't have folder called Ediabas_ecu and when i run FSC_GENERATOR i am getting an error "Unable to load DLL 'api.dll': the specified module could not be found. (Exception form HRESULT:0x8007007e." can any one help by solving this issue or if anyone is kind enough to generate the code for me. Thank you |
FlorinQCK-2.50 |
03-05-2018, 04:35 PM | #1620 | |
Occasional Lurker
190
Rep 590
Current: F87 M2 Competition
Gone: F36 420D M Sport, F30 Tanzanite M-sport, E90 lci Bluewater M-sport, E90 Le mans M-sport, E46 lci 320d SE Topaz blue, E36 318d Compact Montreal blue, E36 318d Compact Titan silver |
FlorinQCK-2.50 |
03-07-2018, 01:57 PM | #1621 |
Rep 2
Hello,
I will like kindly to request some help. I have f30 with business 2014-1 navigation. I got ENET cable and get .fcs file with E-SYS. First I try to install BMW ROAD MAP EUROPE NBT-NEXT 2018-1 but i got message that installation is incompleted. Second attempt is with Road_Map_EUROPE_Route_2018-1 but all codes that i try to generate wit NBT.exe or FCS generators are invalid. Please can somebody provide more information what I'm doing wrong. Thank you in advance.. |
FlorinQCK-2.50 |
03-07-2018, 02:55 PM | #1622 | |
General
10526
Rep 41,145
FlorinQCK-2.50 |
03-17-2018, 10:13 AM | #1624 |
9
Rep 14
this is the instruction provided into a .txt file of fsc generator
--------------------------------------- Installation: runs only on 32 bit systems For generating right fsc.bat which has to be in folfder EC-APPS: when you want to change year, edit the fsc.bat line 0x05 is 2013 , 0x06 is 2014 , ox07 is 2015 and so on,, the 0x28 is for europe c:\EC-APPS\fsc a.hex 0x28 0x05 > code.txt copy files to the folders mentioned prepare ediabas.ini for use with ICOM (if you have): put interface as REMOTE and insert IP address from IcOM under RemoteHost e.g. 254.169.92.38, using port 6801 lock ICOM for use with ediabas (via browser-interface of ICOM under Channels, or with IToollRadar) start FSC Generator start with left button a file is generated named blabla.fsc middle button starts decoder. load previous generated .fsc file and save as a.hex start decode and the mentioned file a.hex will be created. hit generate button and a file named code.txt will be created, which containms the valid FSC for your car and map insert this code in CIC and you're done. ------------------------------------------- So to work with FSC Generator, Do I need ICOM software? Where can I download the right version? thanks |
FlorinQCK-2.50 |
03-17-2018, 10:21 AM | #1625 |
9
Rep 14
I found on megadrive this bmwaicoder 4.6:
https://mega.nz/#!YUEWAQiJ!yChazS-0_...Zb6TjtZb0ssKrg But the antivirus says It's a virus!? I have a F13 with premium map 2011. Please help me to update the maps. thanks a lot! Last edited by 823; 03-17-2018 at 12:33 PM.. |
FlorinQCK-2.50 |
03-19-2018, 02:04 PM | #1627 |
9
Rep 14
I solved all my problem with this fantastic guide:
http://www.e90post.com/forums/showthread.php?t=1461515 RECCOMENDED! LUCA |
FlorinQCK-2.50 |
