04-10-2024, 06:14 AM | #1 |
Rep 4
Which brakes on my 435i?
I feel like I’m beating a dead horse but I’ve read enough information on the different brake configurations to keep my head spinning for a week. My son’s car he just got is a 2015 435i gran sport. The front calipers are in red and four piston and have a “M” logo however measuring the rotor at 340mm. I was first thinking these are M Performance brakes but then shouldn’t it have the 370mm rotor? The vin decoders I try say nothing about the brakes. I know the previous owner could have easily painted the calipers or did an upgrade. To make sure we buy the correct pads how can I know what setup we actually are looking at? Will a part number on the caliper give a better clue?
TIA |
04-10-2024, 07:56 AM | #2 |
377
Rep 248
Take a look at the back of the caliper where the brake line connects. If there's embossed text that says 370/380 you have M performance calipers that'll only take 370mm rotors on your car. If it says 340 you don't, and they were most likely the grey Brembos painted red, which take 340mm rotors.
04-10-2024, 08:25 AM | #3 |
Rep 530
Drives: 2019 440i XDrive GC
Pads will be the same either way. They're the same caliper, just with a different offset from the hub to fit different rotors.
But more likely they are the stock m sport brakes painted red by a previous owner. Are the rears 2 piston or 1 piston? My guess, single piston floating caliper which would be the "base" m sport brakes, just painted red. Nothing wrong with those brakes. Like I said, same front caliper, just different rotor size paired. So all the same pad options for the fronts from F8x brakes, M performance, THP brakes, and M sport brakes.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
04-10-2024, 08:41 AM | #4 |
Rep 4
04-10-2024, 02:34 PM | #5 | |
1988
Rep 2,169
If standard, probably the 330mm discs; if Brembo, 345mm discs So you'll need the correct pads for the front (M Performance / M Sport etc); but rears is where you need to suss out what's fitted currently I run OEM M Performance slotted/grooved discs on my F31 (370mm / 345mm) with OEM BMW pads; if you want an upgrade and still BMW, go with the F80 M3 pads Part numbers on RealOEM FYI
04-11-2024, 06:34 AM | #6 |
Rep 4
Ok, here’s what I see. The front caliper backside has the 340 on it and the back caliper is single piston, sliding. That would be the standard brake set up, correct? Whoever had it before did a nice job on the calipers and even put an “M” logo on them.
danb19791988.00 |
04-11-2024, 07:19 AM | #7 |
103
Rep 276
Drives: 2014 BMW 228i, 2017 BMW M240i
Bimmerworld has a fantastic article going in dwepth on how to identify which brakes you've got and all the differences.
Here's the article: https://www.bimmerworld.com/About-Us...-Sport-Brakes/ |
danb19791988.00 |
04-11-2024, 12:45 PM | #8 | |
1988
Rep 2,169
Pn.1 ending 223: https://www.realoem.com/bmw/enUS/sho...49#34116792223 And yes; calipers will have been painted IIRC as they come in grey from factory
04-20-2024, 08:13 AM | #9 |
Rep 603
I once 2013 made a post about the whole brake variant disaster they did to us.
Maybe this helps a bit. https://f30.bimmerpost.com/forums/sh...d.php?t=858607
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
