BMW X3 Forum
BMW X3 Forum
      04-20-2024, 09:04 AM   #1
RagaX3
Drives: F25 X3
Non-Run Flats & Run Flats - XDRIVE - Bumpy Feeling
Hi everyone,
I've done what is considered a no-no and put Bridgestone Non-Run Flat tyres on the front of my F25 XDRIVE, while the rear maintain Dunlop Sport Run Flat tyres in good condition.
However, since doing so I have encountered 2 problems which I am unsure is related to the change, and I want to get an additional few opinions on the solution.
Problems:
1. Tyre Pressure Warning light activates for all tyres - Expected, likely needs reinitialising.
2. The car feels "bumpy", almost as if there is a traction or stability problem, when accelerating. It's very hard to describe, kind of like someone breaking on certain wheels occasionally. When coasting it feels smooth. - Could be diff related? but no warning lights.
Thoughts:
1. I believe the bumpy feeling and the warning pressure light is related to the mixed tyres, however I am open to other thoughts on this.
Solutions:
1. Change rear tyres to Non- Run Flats to match the front (Cheapest Option), but an I do this? or will the problem likely remain?
2. Accept a loss on the front tyres, and revert them back to Run Flats.
Any thoughts on this? I've done some searching, but I can't find much around this bumpy sensation I've been experiencing. So apologies if this has come up before.
      04-21-2024, 12:22 AM   #2
drukpa
Drives: BMW X3
Change all non run flats, same brand and size.
Different tyres will damage your transfer case in the long run.
I have changed to non run flats, no problems, and much better ride quality.
      04-21-2024, 11:45 AM   #3
mwat
131
Drives: E46 M3 & LCI X3 35i M Sport
2016 BMW X3 35i  [0.00]
2001 BMW M3  [0.00]
Would you describe it as a tugging sensation?
I'm told that's the transfer-case needing new fluid and a recalibration.
My other suggestion would be to run a higher tire PSI all around.. 33/34/35
      04-22-2024, 10:53 AM   #4
RagaX3
Drives: F25 X3
Tugging is certainly one way to describe it.
From what I can tell after more research it related to the new tyres.
I have 225/60/17 all round.
Th originals on the back are Dunlop Sport RFTs, the new ones are conventional non-run flats, Bridgestone Turanza T005.
What I am hoping to find out now before I buy any more tyres is:
1. Will making sure all tyres match with non-RFTs resolve it..
Because if I put new tyres on the back and the issue remains, I might rage destroy the car.
      04-22-2024, 11:35 AM   #5
mwat
131
2001 BMW M3  [0.00]
I can tell you after changing from RFT's to Non-RFT's on all 4 corners I experienced a similar sensation. I brought it to two master tech's and they both said they couldn't feel what I was describing. In my research the answer is to change fluid and recalibrate. However, since I received a good bill of health from two different BMW master tech's I left it alone and bumped up my tire pressure in all 4 corners. That has definitely improved the sensation. I'm at right about 60k miles so I'll probably change the fluid anyway here shortly.
      04-22-2024, 01:29 PM   #6
RagaX3
Drives: F25 X3
Interesting, also very concerning...
I believe it's the diameter that affects it, so increasing or decreasing the pressures could certainly improve or potentially fix it from what I've understood.
I'll attempt to measure my rear tyres vs my new tyres, as I've read some tyres are actually bigger or smaller than what's actually marked on the sidewall.
I have a friend with some BMW software, I can attempt a recalibration but was hit with a low voltage problem, I think I have an unrelated battery problem to resolve too.
      04-23-2024, 07:13 AM   #7
mwat
131
2001 BMW M3  [0.00]
Funny you say that, the master tech's that drove my car pulled my codes and saw under voltage and SWORE a new battery would fix it. Which it didn't, but that's okay I'm not gonna be stranded anywhere anytime soon.
      04-24-2024, 02:10 PM   #8
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
Rolling diameter is at best an approximation. I'd suggest going to the manufacturers' websites and look at the technical data for the tires you actually have. What you're looking for is the revolutions/mile or similar measurement.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project
2012 Alpine White X3 xDrive35i - My new snowmobile.
2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive.
      05-03-2024, 08:06 AM   #9
TEF
112
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
I agree with the rolling-diameter theory. Even tires of the same size from different manufactures can vary slightly in diameter. And this change in circumference is hard on the transfer case (because the rate of rotation varies from front to back). Another way to view this is that the price of another pair of tires is less than replacing your transfer case.
      05-03-2024, 12:31 PM   #10
mwat
131
2001 BMW M3  [0.00]
This is true. However, I confirmed that the tires I replaced my runflats had identical rolling diameter and I'm still experiencing this on occasion. Here enters my tire PSI theory, but what do I know.
      05-03-2024, 02:44 PM   #11
TEF
112
2016 X3 28d  [0.00]
The factory label on my car's door jam already recommends different psi settings from front to rear (32 and 35 respectively), so how does one adjust this to conform to the "tire PSI theory"?
      05-03-2024, 05:58 PM   #12
mwat
131
2001 BMW M3  [0.00]
My own personal theory that the TC likes higher psi on non run flat tires.
xbimmers
