BMW X3 Forum
BMW X3 Forum
      11-01-2018, 04:08 PM   #67
badger8169
Drives: BMW X3 2012 F25
manuals
Hey there,
Im reaching out for knowledge, and divine inspiration ! can anyone out there guide me through removing the headlights to get at the control ballast. X3 2012
Do I have to loosen / remove front bumper?
Many thanks in anticipation
      12-05-2018, 07:14 PM   #68
reybenbmw
Drives: BMW X5 35D
Nice
Nice having those Service manuals.
      01-15-2019, 07:37 AM   #69
CollinR
Drives: 2012 BMW X3
Hi guys,
I am from South Africa and new to this forum. I just bought a 2012 X3 and want to upgrade the sound system. I just cant seem to find the factory amplifier. The head unit is Alpine though and it's a 7 speaker system.
Any idea where i should look because the pics I googled on the internet is completely different to my car. looked through the left and right rear panels = no amplifier
Is it possible that the entire system may be running of the head unit? I did notice that there is a fibre optic cable as well.
      01-20-2019, 01:49 PM   #70
Dott
Drives: X3 M40i
Question 2019 Training Manuals?
The manuals are great, thank you for posting. Is there a source for more up to date training manuals? I am looking specifically for the training manual set that would cover the 2019 X3 M40i.
      05-21-2019, 03:35 PM   #71
Metafan
Drives: X3 F25
New here. Glad i joined this wonderful community
      08-18-2019, 08:32 PM   #72
Vando
Vando
Australia
Drives: BMW X3 3.0D 2013
Thanks for sharing - this is great!
      08-22-2019, 07:49 PM   #73
frogman27
Drives: Bmw x3
Thanks for sharing
      09-17-2019, 07:38 PM   #74
TheCooper5
Drives: 2016 x3 i28
Thanks for posting this info
      09-25-2019, 07:10 PM   #75
RHoppe
Drives: 2017 X3, Msport, xdrive, 35I
These explain a lot! Thanks.
      10-08-2019, 07:41 AM   #76
madrak73
Drives: BMW X3 F25
2011 BMW X3 F25  [0.00]
thanks you
      10-14-2019, 04:30 AM   #77
octodad
Drives: audi a4
Sorry to be a muppet but where is this manual all I see are text comments not atrchment so pdfetc.
(I'm looking in the app on iOS)
      10-14-2019, 05:55 AM   #78
HopefullyHelpful
Drives: BMW X3 20D F25 (N47T)
Hi octodad. Post #1 by plymjack in this thread has the pdf's as attachments for downloading, although I am viewing on my Windows PC, not ios. Maybe that's the problem.
      04-06-2020, 01:59 PM   #79
bronwenw
Drives: BMW X3 F25
What is this in BMW X3 F25?
Hi All,
Please could someone advise what this "plug" is circled in blue. Hubby jump-started our other car and used this as the negative terminal. The X3 just died and we haven't been able to revive her since.
Your advise and information would be greatly appreciated!!
      04-06-2020, 02:21 PM   #80
Wgosma
Drives: 2012 F25 X3 28i (N52)
Not sure about that connection, but any electrical marked RED is always positive.
For jump start need to + cable clamped into the larger terminal, flip up RED plastic cap. Negative can go in the nut lower center in my attached pic
      04-06-2020, 02:33 PM   #81
bronwenw
Drives: BMW X3 F25
Thanks but the problem is we used the thing marked in blue as a negative terminal and now car doesn’t want to start!
      04-06-2020, 02:48 PM   #82
Wgosma
will the starter motor even try to turn the engine over? If nothing happens when you press start button a fuse or relay may have been fried from the initial jump attempt. so you'd need to inspect/test - my guess is it's a relay that has failed.
      04-07-2020, 01:58 AM   #83
bronwenw
Drives: BMW X3 F25
Thanks so much for this. Now the big question, how do I identify which relay/fuse fried??
      04-07-2020, 11:32 AM   #84
Wgosma
Take a look in the Owners manual- I think it will tell you the location of the fuse and relay boxes. They are in more than one place- behind glovebox, behind side panel in storage area behind rear seat.
Fuses can be removed and you can visually look at them to identify if they are good or blown. I am not sure how to check relay condition.
You may need to get car to mechanic to sort this out.
      04-08-2020, 05:59 AM   #85
bronwenw
Drives: BMW X3 F25
Thanks so much for at least trying.
Keep well.
      05-29-2020, 05:32 AM   #86
Sandy5454
Sandy
Drives: BMW X3 30D
2016 BMW X3  [0.00]
Great PDF collection
great many thanks for this
      07-29-2020, 03:18 PM   #87
juliagrace@aol.com
Drives: X3 BMW 2020
Training manual
This was helpful. Thank you,
      10-29-2020, 07:03 AM   #88
mtcyrider
Drives: BMW X3 F25
2013 x3 f25
Hi, I have a X3 F25 with N20 engine. The camshaft timing need to set for the timing chain replacement, when number one cylinder at TDC. After when the camshaft at proper settings, I'll be able to install the camshaft locking tool My question is, is there any marks, on the camshaft, which will help to syncronize the engine. As of now the engine semi apart, no chain no vanos no spockets on the camshaft. If you can help I appretiated
manual
xbimmers
