02-16-2023, 03:54 AM | #1 |
829
Rep 3,982
Crunching/Cracking Front Suspension Noises
My i4 M50 has about 5000 miles on it. For the last 1500 miles or so, the front end makes creaking/clunking type noises when going over simple gutter dips, speed bumps, etc. Doesn't always do it, but 80% of the time. Kind of irritating since the car is otherwise very quiet. Hard to believe that I'm the only one with a car afflicted with this. On the other hand, I think a technician would have a hard time trying to pinpoint the source while the car is on a hoist.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
02-16-2023, 10:35 AM | #3 |
Rep 443
Hmmm I wonder if the dealer forgot to remove the shipping blocks on the front springs. This happens from time to time in the last 20 years or so and pop up every now and then.
02-20-2023, 09:10 PM | #5 |
Rep 709
Have you looked at the car underneath?? You didn't say.
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star |
02-22-2023, 04:17 AM | #6 |
829
Rep 3,982
I'm pretty sure it is all covered with under panels that would have to be removed to inspect the suspension. I can hear the noise going over a bump, but subsequently when deliberately trying to go over more bumps to hear the noise, it doesn't always happen. Wonder if it is some kind of rubber bushing that makes noise on first extension, and then later on kind of becomes more pliable. But the car also sounds like it actually scrapes the bottom lip pretty easily over little intersection dips. Nothing serious, but you hear it. I'm just not sure if it is actually scraping, or just an extension of that other suspension noise. The car is otherwise rattle-free and quiet, so this suspension noise sticks out like a sore thumb.
02-22-2023, 07:11 AM | #7 |
Rep 709
So you haven't looked.
I don't have my i4 yet but in every car I've ever owned you can at least see the spring/damper etc by looking in the wheel well. As stated above you should at least make sure visually the shipping blocks aren't still on the springs. I am not sure how you expect to get anywhere using theory alone and asking internet friends. If I suspected some issue with my car I'd be making it my priority to solve it, if only for safety. Since no one else has confirmed these noises maybe take it to the dealer under warranty?
heatmizr [Todd]
02-23-2023, 11:37 AM | #8 | |
829
Rep 3,982
02-23-2023, 05:32 PM | #9 | |
Rep 1,973
Two days later the battery was replaced along with a new rear axle assembly. They will just debug it and charge BMW for warranty work. Don't sweat it.
2023 i4 M50 - Tanzanite II, Individual Full Tartufo, 20" wheels, all options, PPF, ceramic coating, tinted, lowered (Eibach)
deutsch1004084.00 |
03-01-2023, 09:31 AM | #11 | |
Rep 1
New BMW I4 M50 BMW Clicking and Creaking when turning the wheel
03-01-2023, 10:14 AM | #12 |
Rep 681
You should contact your SA and let them know you've been in another i4 that doesn't make this sound. Or better yet if they have an i4 on the lot have them prove their statement on that i4.
03-10-2023, 05:24 PM | #13 |
Rep 443
hotrod182
Looks like there is a service bulletin for suspension noise: https://g42.bimmerpost.com/forums/sh....php?t=1999946 |
03-15-2023, 08:38 AM | #14 |
Rep 709
Is it the same issue, or a different one?
The fix posted there is NOT the same as in the video here, it's new Tie Rod ends. I linked to this thread over there.
heatmizr [Todd]
03-16-2023, 12:10 AM | #15 |
829
Rep 3,982
The tie rod explanation makes sense. I am going to see if I can figure out what kind of steering rack is in mine. In the last week, 90% of the noise seems to have gone away. Perhaps its all the moisture from the recent storms.
08-17-2023, 06:43 AM | #16 | |
Rep 1
04-30-2024, 11:42 AM | #17 |
Rep 14
I've just started to experience a creaking noise from the rear suspension. It sounds like creaking as I can hear it when the car comes to a stop and the body is still in motion. It was a warm humid day. Then in the evening I didn't hear it and I think it was because the ambient temperature dropped. I am coming up on my 24 month service. I will have it checked out then.
04-30-2024, 11:46 AM | #18 |
Rainbow Racer
1008
Rep 2,540
Our i4 xdrive40 has a creaking clunk up front as well, I believe less than 3,000 miles on it. It happens every so often so a tech could easily dismiss it and say it doesn't exist.
In addition, steering wheel when you move it off center has this slight squeal/squeal noise and mild vibration along with the noise. |
05-05-2024, 01:14 AM | #20 |
Rep 8
Just stumbled across this thread. In a German forum someone had this problem due to a faulty mounting/dampening point of the heat pump. This led to colliding the heat pump with the chassis in specific driving situations.
More info and picture here: https://www.motor-talk.de/forum/i4-4...24.html?page=9 |
