12-05-2020, 07:47 PM | #23 | |
105
Rep 285
Drives: 2014 428i XDrive
BTW, one thing about the setup I had, i really liked it in the beginning, but I got tired of it. I was wishing for a more comfortable ride after hahah. I hope the B6 + 18s will make it feel better rather than b14 coilovers and 19s haha |
12-05-2020, 07:53 PM | #24 |
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
Carparts.com is the site... that's all I got... 19's are terrible for comfort as you well know... 18" which I have are on the edge but i wouldn't do 17"
12-05-2020, 11:03 PM | #25 |
99
Rep 98
FastF30 for your reference:
Eibach E10-20-031-05-22...was able to get a pic of the gap. The first pic is the front. I assume tire size would also fill in the gap. 235/35/19 front and 265/30/19 rear |
12-05-2020, 11:17 PM | #26 |
Rep 1,288
fudge.. I really like my height... I'm 25-3/4"F ... I have to go up 3/4"... well... won't have to worry about inclines as much on driveways... better safe than sorry... stock mine sat 27-3/8"F
12-05-2020, 11:28 PM | #28 |
Rep 1,288
For you smak168 the pictures I told you ... your message made me feel a little better... FaRKle! what is your opinion... I'd really really appreciate it...
bfiddyeight4.50 |
12-06-2020, 04:29 AM | #30 |
156
Rep 178
Sorry for stealing the thread, but im planning to lower my f36 xdrive next spring with KW street comfort coils along with 20" wheels. Will this be a pain 😅 ?
12-06-2020, 12:14 PM | #31 |
Rep 1,288
IMO 20" is way to big for the fact that you will have basically zero side wall unless you increase tire size which will effect your speedo etc... 19" rides harsh... I have 18" and say it's the thinnest sidewall I'd go if you have chitty roads... If I lived in Florida I'd consider 19"... maybe...
12-06-2020, 12:29 PM | #32 |
Rep 1,288
So after reading tons and watching videos etc etc... H&R springs have 1.60 drop (40mm) which I'm at... camber is set to stock measurements... shouldn't be an issue...
lonecitizenfour I think you said the side that failed is the side where the axle support bearing is (passenger side)? I'd highly check that... Parts don't look to bad of price since aftermarkets came out... check this site... |
12-06-2020, 03:40 PM | #33 | |
105
Rep 285
12-06-2020, 04:01 PM | #34 |
Rep 1,288
12-07-2020, 11:06 AM | #35 |
105
Rep 285
So, FastF30 and everyone else... I found out what went wrong. The shop that has my car said when I was getting my coilovers installed, the shop that did it (they're guessing) either reused a collar screw or misaligned the end of the splines and made the collar screw snap. It's not nearly low enough to mess with the geometry.
It resulted in the made the axle go all fu**y. Everything else is actually fine... I'm going to keep my current setup and just get it repaired Last edited by lonecitizenfour; 12-07-2020 at 11:12 AM.. |
FastF30521.00 |
12-07-2020, 11:12 AM | #36 | |
Rep 1,502
Drives: F36 435xd
Had mine lowered for the last aprox 65.000km. No issues at all. Lowered on ACS springs with the OEM active dampers. Will probably change to a KW DDC coilover setup in the spring.
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
FastF30521.00 |
12-07-2020, 12:11 PM | #37 | |
Rep 1,288
Finding good qualified mechanics is very tuff to do that actually know what they are doing when it comes to aftermarket parts... I have had to hold the hands of everyone that has worked on my car... experienced or not... CP install (leaked...they claimed not until I demanded pressure test)... coilovers (had to figure out setup for that specific model).... Makes me very reluctant to upgrade my HPFP or do meth.... Last edited by FastF30; 12-07-2020 at 12:18 PM.. |
12-08-2020, 03:10 PM | #38 |
Rep 493
Love the look, what components did you use?
12-08-2020, 11:08 PM | #39 |
99
Rep 98
THanks GP0256 ,
Eibach pro-kit E10-20-031-05-22 (these are the correct springs as per the German website...the US site indicates a different spring) Koni SA F80 M3 bump stops...not the non-US M3 ones (these ones are the same as the ones that come with the F36). Thanks to johnung FaRKle! and alohasurftoad for all the help. |
alohasurftoad3127.50 |
02-12-2024, 10:59 PM | #41 | |
37
Rep 60
02-13-2024, 06:49 AM | #42 |
Rep 5,404
I just spotted this old post. How has your suspension been now after a few years? What dampers did you use with the Eibachs?
I ended up using that same -05 Eibach spring kit on my F30 335i XDrive. The drops are different on my chassis. The 4-Series starts out lower to begin with: Front 1.4” (35mm), Rear 0.6” (15mm) On my car the stock reverse rake that BMW builds into the suspension makes the front tire/fender gap about 0.75” more than the rear. So this setup makes the tire/fender gap just about even all of the way around. I’m very happy with it. See photo. The Eibach -06 kit available in the US and the -05 kit available in Europe use the same rear springs and the same spring rate in the front springs with just different lengths. I use a German retailer originally recommended by FaRKle! Excellent service, good prices, quick shipping. Usually receive in less than a week. His email is: Andreas DOT schade AT gmx DOT de |
