01-08-2021, 12:42 PM | #1 |
Rep 595
Interior SMD change
After wanting to change these for a long while I finally got the motivation after seeing another forum member had already beat me to it with the gearknob. I've began changing over my interior smds. First up I changed the sport and eco Pro to Red/blue to match my 6wb.
I intend on changing the traction and P buttons to white but I've misplaced my white smds. Here's the first parts I'll update as I get on incase any other members want to see the final results. Another couple bits done while im bored. The footwell lights are too bright so I'm going to give them a quick tint in the morning with some left over medium smoke tint I have lying around. All of this has changed only the orange classic setting and maintained the white sport mode which I mostly use. Last edited by WillLowe; 01-08-2021 at 03:40 PM.. |
01-11-2021, 03:00 PM | #3 |
Rep 4,653
You must be bored pal!!
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
01-11-2021, 03:20 PM | #4 |
Rep 595
Yeah. Luckily I'm still working but after finishing work there's nothing at all to do but sit in my digs. So figured I'd keep myself busy with car stuff.
SteveChester2473.00 |
01-12-2021, 06:31 AM | #6 | |
24
Rep 72
Good luck with all the other smd mods! |
01-12-2021, 04:29 PM | #8 |
Rep 595
Thanks. I've mainly used 0805s though some places they were bit to small so I've been using 3528s or 1206s.
Another member posted this which may be helpful Dashboard section - LED 1206 - 30 pcs / LED 3528 -38 pcs / LED 0603 - 8 pcs - [x] Cluster - LED 3528 x 12 white - [x] Headlight switch - LED 1206 x 6 white - [x] Laneswitch/warning buttons - LED 1206 x 2 white - [x] Steering wheel buttons - LED 0603 x 8 white - [x] Start/stop button - LED 1206 x 3 white/blue - [x] Doorlock + Emergency light buttons - LED 1206 x 1 white - [x] Climate control ambient light - LED 1206 x 4 - blue/white - [x] Radio controls - LED 1206 x 12 - 10 white/2 blue - [x] Airco controls - LED 3528 x 22 white - [x] Cupholder ambientlight - LED 1206 x 2 - blue/white - [x] Footwell lighting left - LED 3528 x 2 - blue/white - [x] Footwell lighting right - LED 3528 x 2 - blue/white Midconsole - LED 1206 - 27 pcs / LED 0508 - 8 pcs - [x] Parking + sport buttons - LED 1206 x 5 white - [x] Gearknob - LED 1206 x 7 white - [x] iDrive buttons LED 1206 x 7 white - [x] iDrive halo LED 0508 x 8 blue Ceiling front - LED 1206 - 7 pcs / LED 3528 - 4 pcs - [x] Ambient lights - LED 1206 x 4 blue/white - [x] Light control buttons - LED 1206 x 3 white - [x] SOS + Airbag - LED 3528 x 4 white Ceiling back - LED 1206 - 7 pcs - [x] Ambient lights - LED 1206 x 4 blue/white - [x] Light control buttons - LED 1206 x 3 white Doors - LED 1206 - 11 pcs / LED 3528 - 7 pcs - [x] Front left controls (driver) - LED 3528 x 7 white - [x] Front left ambient - LED 1206 x 2 white/blue - [x] Front right controls (passenger)- LED 1206 x 1 white - [x] Front right ambient - LED 1206 x 2 white/blue - [x] Back left controls - LED 1206 x 1 white - [x] Back left ambient - LED 1206 x 2 white/blue - [x] Back right controls - LED 1206 x 1 white - [x] Back right ambient - LED 1206 x 2 white/blue |
03-23-2022, 04:46 AM | #13 |
Rep 4,939
Drives: 340i MPPSK
Those pics remind me of the RGB stuff you see on Linus Tech Tips
Good stuff, you obviously have a talent for this kind of work. I'm the sort of person who leaves most DIY well alone as I'm a measure twice, cut once and still gets it wrong sort of person.
Life is a state of mind |
05-07-2024, 04:43 PM | #14 |
Rep 20
I would like to try this on the footwell. question you put LED 3528, will these be as bright as your picture? I would like to try purple and white brighter than stock.
05-08-2024, 12:32 PM | #15 |
Rep 7,034
Drives: 335xd Msport +
Good work.
You can do the gear knob LEDs as well. I ( or rather my son) did mine using a flea bay kit - green for drive , red for park, amber for neutral,white for reverse and of course blue for sport mode. I did have to put some tint on the green however as it was quite bright.
