04-17-2024, 01:54 PM | #1 |
Rep 1,890
Nearing 100k on N57 Maintenance advise needed
What's up fellas, my 2014 535d M Sport is nearing 100k miles. It has been an amazing ride so far with just basic maintenance. I love the car and want to keep it for a long time as it still looks and rides like new. Does anyone have a link for recommended 100k servicing? TIA!
04-18-2024, 02:33 AM | #2 |
Rep 821
Its all a bit of personal opinion to be honest and it always depends on what your intervals are up to that date. If you haven't already, my list would be:
Some things to keep checking for at this age:
Ive only had 2 cars past 100k, and ive always ended up cleaning the washer bottle with a bleach solution too |
BMW BRAD212.50 |
04-19-2024, 12:10 PM | #3 |
Rep 1,113
At 100K, I would do the following:
Swap chain tensioner to the latest version. Check the crank pulley damper for excessive play. Check the cam cover gasket for leaks and replace if it is leaking before it drips onto the exhaust manifold and causes a fire. Cam cover PCV rubber diaphragm. PCV hose to the turbo inlet. Oil filler cap housing O ring. Oil filter housing / heat exchanger gaskets. If the budget allows, maybe a walnut blast of the cylinder head ports/valves and ultrasonic clean of the intake and injector nozzles. |
BMW BRAD212.50 |
