10-22-2019, 06:06 PM | #309 |
Rep 3,897
What happens when you go back to XDrive - does it go back to the original, BMW software, or does it still use an XDelete flash with AWD enabled (which may very well differ from the original spec)?
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
10-26-2019, 11:18 AM | #310 |
Rep 552
I was able to flash back to xDrive using a device from iOS 12, so may be an issue with the latest iOS 13.1.3 (or it's just my device/cable).
Reverted back, because I kept losing traction/power when hitting bumps on Philly city roads, and didn't feel that confident in taking higher speed turns in the rain. Assuming that it flashes back to the original xDrive map, but not sure. |
10-29-2019, 02:33 AM | #312 | |
112
Rep 333
This is something they didn't experience on their test cars but apparently can happen. I guess that is the risk getting a product from a smaller company that can't do very long run tests on each car. Very good that they added that. It shows that they are on top of things |
10-29-2019, 05:50 AM | #313 |
Rep 3,897
Well, it shows they are responsive.
"On top of things" is avoiding it on first place. Hope no other, more serious surprises come up in time. What year is your car and how many KMs does it have? Wonder why no one else has complained about it yet.
akgambino271.50 |
10-29-2019, 07:00 AM | #314 | |
Rep 3,897
According to the XDelete developers it is not the same software. Even when you go back to XDrive you keep on running XDelete, just in AWD mode. They claim however it is exactly the same ruleset as stock, so the car should behave as stock. I wonder to what extent that is true, as it was again the XDelete guyzs that claimed that there are differences in XDelete from model to model or even from engine to engine within the same model... Please keep us posted whether you notice any difference in XDrive from before (stock).
akgambino271.50 |
10-29-2019, 07:24 AM | #315 | |
112
Rep 333
The car drives the same for the last 2000 miles |
10-29-2019, 07:39 AM | #316 |
Rep 3,897
Thanks.
When you say "the same", do you mean the same as pre-XDelete (no noticable issues) or....? Are you driving in Xdrive now?
10-29-2019, 07:56 AM | #317 |
112
Rep 333
10-30-2019, 08:06 AM | #318 | |
2088
Rep 2,649
If people had issues, they would complain like no other.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
11-01-2019, 02:24 PM | #319 |
Probably fixing some broken shit
9
Rep 30
So I purchased xdelete and am attempting to flash on a 2013 bmw 335i xdrive with a manual transmission using a galaxy s10+ with the obd2 to ethernet option and keep hitting an error on "preparing vgs" I've tried every solution under the sun with no luck, xdelete support has been slow getting back to me, anyone else been having this problem and found a workaround?
11-01-2019, 09:27 PM | #320 | |
274
Rep 290
11-02-2019, 06:55 AM | #321 | |
poopycat
266
Rep 791
Seems like 4 people have it working, 3 people don't. 4 people may not have a warranty later on, too. |
11-02-2019, 09:54 AM | #322 | ||
274
Rep 290
11-13-2019, 02:19 PM | #323 |
10324
Rep 2,679
I reckon it's been long enough that plenty of members have tried x-delete.
Any thoughts on 30+ hp gain? This seems so far fetched it makes me question the legitimacy of the app to be honest. And I definitely want to know how to flash back to stock xdrive, not x-deletes version of x-drive, I never thought of that. |
Skyhigh1908.00 |
11-13-2019, 03:18 PM | #324 | |
Rep 3,897
My thoughts: User experience: I suspect most who tried it went back to XDrive for the winter. Long-term experience is probably not to be expected before next summer. hp gain: unrealistic for any noticeable increase. Someone already provided a good explanation why you may observe some gain on a stand. IF there was an undoubtedly verifiable gain, be sure that XDelete would be writing it with big letters multiple times on every page of the brochure, as this is a powerful selling argument... Make up your own mind why they are not advertising with that... X-Delete XDrive: This is currently a big showstopper IMO. Somewhere in their (quite chaotic and ambiguous) paperwork, XDelete themselves stated that XDrive varies not only between models, but even within the same model, between engine types. I don't know if that is true, but if it is, than how can the XDelete's XDrive not be (potentially) different from stock!? I must admit I might be willing to give it a try but only if I can revert back to Stock.
floridaorange10323.50 |
11-13-2019, 09:20 PM | #325 | ||
Rep 1,934
11-14-2019, 01:08 AM | #326 |
Rep 3,897
Don't assume, inform yourself first! See what XDelete are stating. They state no backing up. It is an XDelete Xdrive mode.
If I am wrong - let me be proven wrong, I'd be happy to. I'm only stating what's already on their facebook page. Apart from that - feel free to do whatever you want on your car with or without thinking, as you can and prefer. Let others think for themselves however.
11-14-2019, 12:03 PM | #327 | |
Rep 1,934
They would not build the protocols or module code that reads sensors, bmw has already done that. Any of these tuners simply change what the bmw code expects from certain sensors. "Hey DME don't close the wastegate until this LOAD READING" or "keep dumping fuel until you reach this AFR". All they are changing is the load reading or AFR to expect. For Xdelete it's simply "dont close this clutch" in the transfer case" or "don't send torque to these wheels even though these other wheels are slipping this %". For comparison a JB4 will spoof the values some sensors are reading. You don't need to propagate your own fears to everyone else becuase YOU can't grasp readily available information, or do your own research. Xdelete is a proven application installed on thousands of cars for several years. You sound like the religious zealot clamoring about the world's end in a subway stop.
11-14-2019, 01:46 PM | #328 |
Rep 3,897
Your profession at least explains the 2-dimensional thinking...
Whilst you still make pure assumptions, they are not unreasonable. The question you are clearly failing to ask yourself however is WHERE the source data is coming from (not your problem as a software engineer, right?). Option 1: It is downloaded from the subject vehicle, modified and compiled in real time and overwritten on the controller Option 2: It has been extracted from any random F3x 2 years ago, modified by XDelete and all you do is overwrite your stock SW (which may very well deviate from the one XDelete based theirs on) Now you tell me, as a SW engineer, which of the 2 options is more likely, given that the whole procedure is done via any commercial smartphone within minutes!? And I quote XDelete again that there are differences in XDrive's distribution (ruleset) even within one model, depending on the engine. (I personally don't know if that is true) Once again - never assume! If you call yourself an engineer, the only assumption you should ever make is that you do not know everything. That will always be a correct one. And last but not least - I was actually responding to the "fears" a.k.a. as thoughts of another user here. Your opinion and assumptions are well noted.
11-14-2019, 08:13 PM | #329 |
Rep 1,934
You are asinine.
kern4174462.00 |
11-15-2019, 08:34 AM | #330 |
10324
Rep 2,679
Skyhigh - I come to Bimmerpost to hear from members on experiences with various 3rd party applications - in this case X-delete. "Researching" what the vendor claims are not why I'm here. Of course I will cross-examine my findings on Bimmerpost with my own experience as well as research the vendors info. Thanks for your concern though mate.
