Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > How to test high beam assistant in daylight?
      06-28-2008, 12:33 PM   #1
Juntta
Finland
Drives: 325dA Touring -08
Hi!
I want to know how I can test the high beam assistant in daylight? Since in Finland it isn't dark enough at night in summertime!
Little background for my question: I wanted to install homelink mirror to my E91. I had autodim mirrors already and the high beam assistant, no clown nose though. So I found mirror from -07 M5 on Ebay which had homelink + clown nose also.
I was able to switch the mirror and it worked almost perfectly: I was able to use homelink buttons, mirrors dimmed ok and rain sensor worked. Only thing I wasn't able to test was the high beam assistant - when I turned on the assistant by pushing stalk forward and covered the sensor in front of the mirror with my hand, high beams didn't turn on.
Does the high beam assistant react to other sensor as well (like the light sensor next to rain sensor)?
Hopefully you guys can help me out!
      06-28-2008, 02:19 PM   #2
VP Electricity
VP Electricity's Avatar
Drives: F34 xDrive
I'm interested in this as well.. my E91 has the Clown Nose, but I have no idea what HBAssistant is
      06-28-2008, 04:54 PM   #3
Placey
Placey's Avatar
Drives: 08 Z4 3.0SI
cover the upper half of the windshield, as the hihgbeam assistant uses a camera, and possibly the rain/light sensor
08 Z4 3.0SI Black Sapphire/Black Int, 6sp, Sport/Premium --- retired ---
2010 BMW 650GS -- Z4 replacement
Working with the most talented people on the most technically advanced automobiles....
      06-29-2008, 03:03 AM   #4
Juntta
Finland
Thanks Placey, that is what I was thinking too...
If someone could just confirm that this method (cover assistant camera + rain/light sensor) works. Could someone test it who has working high beam assistant? Because mine doesn't work if that is right way to try it...
      06-29-2008, 02:51 PM   #5
tintivilus
tintivilus's Avatar
Drives: E92 335i
2007 E92 335i  [0.00]
2003 325i  [0.00]
You can't get it on a 3'er in the US.
      07-02-2008, 12:52 AM   #6
Juntta
Finland
Bump!
Please, could someone with the high beam assistant test that will it turn high beams on by covering the camera in mirror "foot" and light sensor in windshield (next to rain sensor)?
      07-07-2008, 05:38 AM   #7
Jools
Drives: BMW 320d SE Edition
Hi I've had my car a couple of weeks - and it has HBA - It works really well!!
High Beam Assist is a bit more sofisticated than I had thought - so it may be hard to "test" witout going out for a spin...
Main Beams are normal "Dipped"
High Beams don't come on until you go over approx 30MPH
They Dip again when you go under 25MPH
(This is handy round towns, but not so handy round my narrow country lanes where I am often under 25MPH, but would like the main beams on!!)
Things I have noticed (not done a lot of night driving yet - gets dark about 21:30 in the UK at the moment)
Speed Sensitive - see above
Dips when you go into an area lit with streetlights
Dips when on-coming car approaches
Dips when there is a car infront (must be able to "see" the rear light)
In all - its very impressive - never had to override it (apart from driving slowly down narrow lanes!)
So to test - I think you will have to cover the sensor and then go out for a drive over 30MPH
Jools
      07-07-2008, 06:36 AM   #8
Juntta
Finland
Thanks Jools, guess I have to put some masking tape etc on the light sensor and go for the spin...
