BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > 420D Xdrive transfer case/diff?
GetBMWParts
      03-21-2023, 02:40 PM   #1
e92jg
Drives: e92 320d
Hi all hoping someone might be able to give me a clue, I brought a 420D Xdrive last week 67000 miles.
There is a clunk half the time when pulling away from stationary, similar to a brake releasing from the drivers rear although it varys how loud and much you can feel it. It seems to be worse after being parked for a while.(i have checked all the brakes there is no binding at all)
There is also an occasional vibration/ shudder similar to traction control kicking in from that same drivers rear wheel right through the rev range, especially when acellerating from a rounabout or turning.
It should also be noted that the car has 4 7MM tread tyres with 3 budget and 1 kumho tyre on that drivers rear. Which could explain the acelleration judder but surely not the clunk from pulling away.
Ive heard of the transfer cases being trouble some but it does mainly feel as though its from the drivers rear. Any ideas or checks on the transfer case i can do would be greatly appreciated
      10-18-2023, 02:58 PM   #2
bt49qt28c
13
Drives: had 35 bmws but fav is e63
Had the same issue. Does it often happen when you go reverse and then drive forward to make the "clunk"? And vice versa? If yes, it was the rear cv joint on my 420xd. I replaced the whole axle bar left side and the problem got solved.
      10-19-2023, 07:38 AM   #3
dani802
Drives: BMW F26/F30
On Xdrive vehicles the tyres have a big impact in terms of drivability.
