TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > PROcede V2 on the BMW diagnostic service computer
      10-11-2007, 10:20 AM   #1
e.n335
Moderator
e.n335's Avatar
Austria
321
Drives: e93 ///M3 DCT, 07/2009
Hi guys,
As announced I have been at my dealership today.
I have a PROcede V2 in the car and am the guy who had a limp mode with V2 map 2.0.0 hitting the speed limiter.
The error has been:
30FE - turbo pressure too high ( @ 6208rpm )
Now, we had another issue with the PROcede V2 on newer cars, the expected switched power fuse was not there. I investigated in this last weekend and found a solution.
Thread: http://www.e90post.com/forums/showthread.php?t=88087
Since I hooked up the PROcede V2 to this power source, the 2DED powermanagement warning disappeared as well. Of course, I had this error stored from the 2 days when the PROcede was hooked up to the 50 AMP fuse directly, but there were no entries since the PROcede V2 is hooked up to the new switched power source described in the thread.
I don't know whether Shiv is using this source with his new jumper cable, but if he does we will see no more power drain warnings as well.
BTW, I did a lot of PROcede V2 testing since the one week I have it in the car. The reported issue has been the only one on my side. The car feels great and very strong. Since others had no problems with map V2.0.1 as well, it would be great if Shiv could make different V2.0.1 maps for MT and AT cars again.
Enjoy your great PROcede V2 product ! I hope Shiv will ship out a bunch of V2 upgrades soon.
In other words, PROcede V2 is 100% invisible to the BMW service computer when you have no limp mode .
Cheers
Eugen
      10-11-2007, 10:37 AM   #2
stefano7171
stefano7171's Avatar
17
Drives: BMW e93 335i Msport
Thanks for the Report "Major"!
Current: e93 335 Msport, black sapphire on sanbeige, MT, 19" rims 225m, satnav, usb, CA, voice control, HBA, windstop, heated seats.
      10-11-2007, 10:49 AM   #3
Cookiemonster
Cookiemonster's Avatar
17
Drives: 2010 335XI e92
Originally Posted by 533ogetnom View Post
which was
Got V2...went on high speed run....got half engine light when he hit top speed....promised he would go to dealer and do a scan.....This thread is the what happened at the dealer!
2007 335I sedan (retired)
2010 335xi coupe
      10-11-2007, 11:07 AM   #4
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
dont you think the whole "turbo pressure too high" code is a little scary?
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      10-11-2007, 11:07 AM   #5
Dascamel
Dascamel's Avatar
52
Drives: 2008 e92 M3, 2010 e91 328i
So was the Procede installed when you went to the dealer? I'm assuming you took it out?
I would be scared but in general not planning of bouncing off the speed limiter much in the states, plus the car is triggering limp mode as a safety feature. But yes I have a feeling Shiv should address this one quickly.
edit: Is the new map already out 2.0.1?
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      10-11-2007, 11:09 AM   #6
BoostedBMW
Moderator
BoostedBMW's Avatar
Drives: TiAg E92 335
2003 S2000  [0.00]
Hmmm.... I wonder how many bone stock cars the dealer has seen throw that code?
-Michael.
Berlina Black S2000 CR is now in the garage
l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l
      10-11-2007, 11:15 AM   #7
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
491
Drives: Project Estoril
I havent seen it yet.... And I havent seen it on my personal car yet either. I've topped it out over a dozen times easily too...
Whats the boost at on the V2?
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      10-11-2007, 11:58 AM   #8
Serjames
Serjames's Avatar
187
Drives: E93 335i M-sport
Addressed to those that are worried, i.e. not the Eugens's of the world.
Remember this is an OVERBOOST scenario when the engine management system cuts fuel or what ever it does when the speed limiter is reached.
A similar scenario occured on some other testers cars when they went from WOT to no throttle very quickly.
It's NOT that the turbos are suddenly spinning twice as fast, only that the build up of air post compressor has no where to go and the diverter valve is either not reacting fast enough or it IS, but it detects more air pressure than it was expecting within it's "CONSERVATIVELY SAFE" range of measurement
I.e. I'm not scared, just another example of very good safe engineering by BMW, that we, er need to circumnavigate.
SJ
      10-11-2007, 12:02 PM   #9
e.n335
Moderator
e.n335's Avatar
Austria
321
No, this is not scary. It happens on some cars when you lift the pedal quickly or run into the speed limiter above 6000rpm ( both events close the throttle very quick on higher boost ). The diverter valves cannot blow off fast enough and the code is thrown.
Map v2.0.1 is out and some of us are verifying whether it fixes the issue. It looks very good, this means no issues with v2.0.1. up to now. The OP is the result of one part of this process. It's done that all of you get a great PROcede V2.
The PROcede is always installed in my car. The guys at my dealership help me to indentify issues with my tuning.
Cheers
Eugen
      10-11-2007, 12:19 PM   #10
max boost
max boost's Avatar
45
Drives: 07 335i
eugene hows many key cycles will be needed to take clear a history code?
      10-11-2007, 12:22 PM   #11
leftcoastman
Drives: 335i
^ +1
Does a diagnostic read still pull up your old power codes?
      10-11-2007, 12:29 PM   #12
judec
born to be turbocharged
judec's Avatar
Slovakia
25
Drives: Not a bimmer yet
one thing is it's not scary, cuz we possibly know why did that happen. Anoher thing is maybe the new Forge valves could provide a solution and release the pressure faster. Another thing is that if U dont have a fellow dealership and some hole notices the code, he could eventually report that to BMW, cuz under normal circumstances such a code should not appear, so this could be a trojan horse for V2 users... but this is just a speculation, dont flame me.
THX Eugen, great info, as usual. What's new with your car PC?
Disclaimer: All this message was written with recycled electrons.
      10-11-2007, 12:33 PM   #13
e.n335
Moderator
e.n335's Avatar
Austria
321
There is a limited buffer for all the events. At least the last 3 occurances of every event type are stored. Keying on/off the car will not help. The events are stored until they are deleted or the FIFO ( first in - first out ) logic kicks them out.
- Eugen
      10-11-2007, 12:42 PM   #14
e.n335
Moderator
e.n335's Avatar
Austria
321
Originally Posted by leftcoastman View Post
^ +1
+1
      10-11-2007, 12:42 PM   #15
DrDomer
DrDomer's Avatar
Drives: 2004 330ci ZHP, 1999 Miata
How many days does it typically take for these type of codes to be cleared? Can they be cleared with time?
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. ~Albert Einstein
      10-11-2007, 12:46 PM   #16
jon@themshop
jon@themshop's Avatar
Drives: BMW
They won't be cleared till a BMW diagnostic computer or some sort of diagnostic tool clears it. Even if the limp mode or SES light goes away, a "cold" fault will still be retained in the DME.
      10-11-2007, 12:46 PM   #17
Sniz
Sniz's Avatar
769
Drives: e92 335 - gone // e36 M3 turbo
I dont think so, but i'm certainly not a BMW tech. I think they will be stored until they are cleared.
      10-11-2007, 12:47 PM   #18
e.n335
Moderator
e.n335's Avatar
Austria
321
Confirmed.
      10-11-2007, 12:48 PM   #19
DrDomer
DrDomer's Avatar
Ahhh.. Ok.. It'll store 3 such events till either further events happen to kick the oldest out or they are deleted.
      10-11-2007, 12:54 PM   #20
timtech
timtech's Avatar
27
Drives: M3
Does a product like this allow you to clear the events?
http://www.obd-2.com/
I have one available but my car is in getting a fuel pump today so I would guess everything will be cleared.
I know I never seen the error on the c-reader.
      10-11-2007, 12:57 PM   #21
e.n335
Moderator
e.n335's Avatar
Austria
321
At least ...
After every major PROcede install ( when the wiring changes ) I let clear the error codes in my ECU so I have a clean and defined basis to analyze, if I like/have to. Of course, it will not be that easy for you in some cases. Decide if you want to ( hint, hint, hint ! ) when you want to avoid discussions in some cases. You will have to pay for it, it lasts about 15 minutes.
- Eugen
      10-11-2007, 01:01 PM   #22
DrDomer
DrDomer's Avatar
I wish I had that relationship with my dealership.
